the screws that you have are most likely for the 1971 Road Runner which uses the same tail light lens but without the bezel. the thickness of the bezel is your difference. the 71 GTX screws are slightly longer . Cant tell you the exact length ,it was a long time ago , but you might try getting in touch with 71GTX he may have some laying around.
