Yeah binding cable perhaps.. weak spring or i have had the kickdown arm rub the bottom of a drop base air cleaner too.
Did it again without air cleaner. Spent 15 minutes in neutral revving without binding. Has 3 springs on it, it’s got a solid return.
I’ll order a new throttle cable just in case. I’m still stumped and now I have to fix the paint from hitting a welding cart before I got it shut down while putting it gear. Yes, I’m a dumba** for doing it in the shop.
Maybe I’ll order a cable kick down too. It has a rod style setup now. I didn’t get it to bind but maybe
