I think I would drop the drive shaft and check the pinion nut to be sure it has not backed off (loosened up). There seems to be an issue with the modern 9 1/4 (and 8 1/4) rears having this issue. Drop the driveshaft, put a socket on the pinion nut and be sure it is tight. Gene
