If you confirm your ignition setting have not changed you might want to make sure your cooling system is full and functioning properly, low coolant level will allow the temperature of the heads and combustion chambers to rise and cause ping. Also a lean fuel mixture will contribute to pinging (vacuum leak or carb problem).
