Actually on some port configurations with a steep short turn radius, I've found that varying the seat angle anywhere from 43 degrees on one side of the seat to 54 degrees to the other side produces impressive results. The angle under the seat has to vary also but I won't elaborate on those angles. I have gotten as much as 346 cfm out of a set of 906's by varying the angles.
