You want the standard rotation steering box. The reverse rotation boxes are for 4wd and have the sector shaft come out the side. I think the 4wd boxes switched to standard rotation around '78ish. I believe all 2wd boxes were standard rotation. Not sure if the pitman arm will interchange or not, between manual vs power steering boxes.
