I'm using one. The nicer dark blue billet style they discontinued (they didn't
make them for very long...they're not easy to find...so I collect them, so far have only found two).
You will probably be fine as long as you don't experiment with additional electric accessories.
The charging system will be at it's limit with what little draw it has. Idle with the headlights on is pushing it.
I use the same 5 blade fan, but went to a much tighter RV clutch due to low speed cooling concerns.
(not verified problems...just concerns).
I'm not 100% sure if the loose/power saving MP fan clutch (6 cylinder van application if I remember correctly?)
will be adequate for you when spun at lower rpm. I think it will probably be fine but that is something
to keep an eye on.
Overall I'd say you are probably good to go.....but....."it depends"
"You have to test on your specific combination and...."
![blah blah](/ubbthreads/images/graemlins/custom/blahblah.gif)
You already know the rest
![no no](/ubbthreads/images/graemlins/custom/no.gif)
