Originally Posted by csk
Is that with zero lash ??? you said it was a solid. the lash is taken off the gross lift #.
Yep, that's adding the .012 to the #. Which reminds me, need to call Erson and see what they recommend for lash. This is the way it was set from engine builder.
Bringin Back the Iron!
