I have a slightly narrowed Strange 60 rear using Dr. Diff’s 1” spring relocation shackles....
So, what would be the best solution to use a factory style rear sway bar? Is heating the
Bar and bending the attach points inward an inch and a half an idea? Are the factory B-Body bars
Narrower than the E-body bars? I am not liking the aftermarket designs that bolt to the axle and they would
Possibly create an issue with my 3” exhaust...... anybody solved this problem before? TIA... TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
