If you look closely you'll see that those bushings were installed and "crimped" after the rubber insulator. You can't get one out without wrecking the bushing or insulator. My guess is for that reason nobody has yet reproduced them. The closest thing you'll find will be a poor knock-off from SF Restoration (a sponsor here). They fit both the insulator and the stud but they don't look correct.
