Originally Posted by CrAzYMoPaRGuY
Are these usually pretty good? My buddy received all new gauges for his 1970 Charger, the clock works in his Tic Toc Tach but not the tach....!?!? He wants a Tic Toc Tach..... any other suppliers? Thanks
The newer repro tachs are compatible with aftermarket ignition systems (unlike the factory unit) or factory point type as well, is he using a factory/aftermarket/repro tach harness?, the Tic Toc Tach wiring installs are often a source of confusion and constant topic on B body forums.... need to know what he's done for wiring, assuming the tach is good and hasn't been fried electrically
