Not stock looking, but I have the Wagner above, and it works quite well. Took a bit of trial and error to get the cruise circuit dialed in, and I'd highly recommend a catch can. If you build is stock-ish in the cam overlap department, I'd save your money. It really shines (and fills the catch can) above 3KRPM. Previously after sustained high speed cruises, I'd have oil dripping out the breather, so I had a long overboard dump on it which would soil the ground or garage floor. Now, I just empty the catch can once or twice between oil changes.
