There are lots of ways to do this, but for me simple is best. I design systems with short wire lengths where possible to help with voltage drop and weight.
The problem with any relay controlled by the battery disconnect switch is the relay uses power and will kill the battery if left on for long periods of time. The higher the relay current rating the more power it takes to operate normally.
