FWIW, I was asking questions on here about the TA 17875XA valve body sometime last year. It might be worth searching on that valve body # and see if anything else you might want to know comes up. At the time I was looking into changing from my TA 17680 to something w/ LBA, since mine's a street/strip car.
Brad we put the A & A low band apply reverse manual valve body in my sons Dart last summer. It had the old Turbo Action valve body I bought in the 80's that was a reverse manual valve body with no low band apply which is the kind I use in my 63. The A & A unit works great in his car as it did not slow down at all and we feel no 2 element fight as the 1-2 shift feels just like it did with the TA no low band apply. We did install their low/reverse servo and spring which they recommended with it. Ron
