Originally Posted By Cab_Burge
I was taught to not measure between the tires for toe in or toe out due to the tires having bulges on them shruggy
Makes sense.
I never thought of that, but have always used the outer most tread to measure. Hook the tape into the tread and measure to the same point on opposite side. Was always good enough for the junk I drive.
I get the ole gals stuff done at the local tire dealership, when we have new tires installed.
I have mechanical Aptitude.
I can screw up anything.
