That was a nice lap right there.
Was it more track , or car that caused you to pull timing ?
we had test and tuned at Irwindale on a normal Thursday night which has minimal prep at best.. we were running very soft on extension looking for extra hit for the crappy track
When we got there we decided the track was going to be good. We figured we would go all in on the tune up.. lo and behold I had forgot to change the shock settings to accommodate the extra hit and bite Quickly decided we needed to remove some Power to Go A to B.. we were actually topping out the extension on the leaf spring and unloading the rear tire about 40 feet out.. the leaf spring tops out well before the shock... we run Springs that are almost flat very minimal Arch..
