Originally Posted By dangina
I am curious as to those who are using this system - is it as great as they say it is? I have seen them do well at track days I am curious as to how they work? I know its just air shocks but how do you adjust for bumpsteer at different ride heights? also how do the rear shocks work in place of rear springs? what I mean I know with coilovers and leafs you pick the rate you want but how do these adjust rear rates? how do sway bars factor in?
You really don't, and the limitation there should be obvious.
"When one’s appeal is emotional, it does not matter if there is no substance."
