Originally Posted By Pacnorthcuda
Originally Posted By mopargem
If you were to use teflon tape, it needs to be the yellow type which is resistant to fuel
Yellow Teflon tape is designed for natural gas and propane lines, not gasoline.
iagree
White for liquid gasoline or diesel scope
OP, do NOT use any sealant on any AN fitting other than the NPT ends twocents
