I 1st used oven cleaner on them to get the grease/oil off. Which made a big difference from the start. All I did was let the oven cleaner set for a few minutes, then scrub with a plastic brush I got from harbor freight. Then I used Mean Grean on top of that, scrubbed some more, then hosed off real good with water.
Right afterwards, I soaked them in the evapo-rust (I have 4 gallons of Saferestremover) and let it set for about 20-30 minutes tops. I scrubbed the bolts, springs and hard to reach areas with another plastic bristle brush. Washed off, then coated with Rust-Veto.
The Rust Veto dried in 15 minutes. Done....
