Originally Posted By stumpy
Intermediate shaft position doesn't mean matter as long as the dist cap is wired with the #1 wire over the rotor tip when the piston on #1 cylinder at tdc of the compression stroke. #1 wire can be on any terminal as long as the rotor is pointed to it at TDC of the compression stroke.
Fixed
In theory, there is no difference between theory and practice. In practice, there is.
