Originally Posted By 69Chrgr
I have a complete 69 woodgrain wheel. wheel, adapter, horn contact switch, and button. I have no harware other than the steering shaft nut. Is the hardware special? Year one has with there repro wheels it says " must use original hardware" I'm not sure if there are insulators? or anything else special. Any help would be appreciated on what it consists of and where to get it.
Duane
U have everything you need. Just add normal hardware, no insulators required.
