Sorry I haven't posted recently. I tried several things. I took Andrews lead and tried a factory Air Cleaner. The original 70 dual snorkel will not clear the A/C but the later model dual snorkels that have the dented area at the front will.
I still want to use the air box but at least I have a plan B now.
I am pretty sure that Andrew is correct and the 94 Fuel pump cartridge will not fit but I am going to try. It is about the same height as the tank but I haven't cut the tank yet to mock up the installation. I will see tomorrow when I cut my spare tank.
If I can't get it to clear I am going to use the hole to try and fab up an in tank pump system.
I will keep you posted.
