Later 5.7L all use SS bolt/studs at rear 2 bolts.Make sure the dealer sells you the bolt/studs with white painted end. Fronts are different. Fix? Drill out the small bolt line up hole in the exh manifolds (manifold can not bind then). Manifold grows and binds,breaks the bolts (not the bolts fault).
