Originally Posted By Andrewh
pretty sure it is 318 and 340 are the same.
360 is different on only one.
and you can use spacers to make up for the difference if you want, or get the correct one.
273/318 same both sides
340/360 same both sides.
273/318 moutn wider than 340/360 mount on one side.
So yes, the 340 mounts will just fit the 360 no problem.
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
