@AndyF: I don't think I'll have any issues with the exhaust since the tubes are the same diameter as the 8.75", but I have my fuel pump and filter mounted to an aluminum plate in front of tank. It fit just fine with the 8.75". Won't find out if that is going to be an issue until I go to install it in the car. I have a custom tank on the list of things to do this season. Might have to happen sooner than later.
@Larry: Need to use Ford housing ends on the axle to get them to bolt on. Since it needed new ends anyhow it wasn't any additional cost. Yeah, e-brake is under the rotor hub. I don't know what is going to be involved with the e-brake cables yet as it isn't in the car. There are a few guys here that have used this exact kit in their cars though.
