It’s a sound that was hard to adjust to (No pun intended) if you have not heard similar fast rate cams
Especially after running a Mopar 284/484 Camshaft and lifters for 25 years in the same block Nice and quiet at idle , right up until I kissed a piston with an intake valve
Hence the rebuild last year
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
