I would find another housing with the bigger tubes, they are out there and not that scarce, I would be concerned about the tube thickness on yours, it may be ok but you will not know untill you cut it, also the mopar ends are designed for the 3" tube size.
Light travels faster than the speed of sound,,,this is why some people seem bright untill you hear them speak.
