Yes, like the others have said, any shifter that would work for a 727/904 will work here. The 95 and earlier transmissions were hydraulic and you would have needed to setup an electronic circuit to turn the overdrive and lockup converter on/off. On a 96+ that's not necessary. You can wire in a switch to disable the OD should you ever want to, however this is not mandatory. The ECU will take care of the lockup converter and OD on it's own.
