Do I have the correct backing plate for a 71 Super Bee with power disc brakes?? I find it odd that the two lowest holes are open plus even the very bottom of the opening.
Is there a backing plate with possibly two lower studs for those holes and then when booster gets mounted it goes through the 4 holes above?
Thanks Ron
IMG_2385 (Large).JPGIMG_2382 (Large).JPGIMG_2383 (Large).JPGIMG_2384 (Large).JPG
