Just noticed you have two extra holes, one has a flat bottom, what is that for? Does it look factory?
I have a picture of a Cuda firewall and that hole was used for the roadlamp harness. I have no idea if that was even an option on 71B's
There is just one extra hole, the one that looks like it has a flat bottom but is paint buildup from behind.
That's the hole I am speaking of, left of booster and right of fuse block nut. I now fully believe it was there and just behind booster. I have nothing left to put there except for a plug. Previous owner had put a reproduction tach in but it is spoken for through the harness.
I had put all my parts as I removed them in the trunk and the trunk is now empty aside from aircleaner assembly and wipers...
speedo cable is in
clutch interlock in
hood release in
hidden headlights in
dash reverse light in
back up lights in
clutch rod in
1"rubber plug near fender in
Ram Charger lines in (passenger side)
NO cruise control
Must need a rubber plug at this point that would be hidden behind booster.
Ron
