You don't need no stinkin' kit. Just cut the stock wheel well down the middle and move it over to the frame rail. Add a strip of metal in between them and you're done.
You'll need to cut the bottom of the trunk hinge bracket off for clearance, then re-weld it to the inner tub once it's moved in. Sorry I don't have any pics of it, but I've had two cars done this way.
