My GTS was born 28 December 67. There’s no place on the broadcast sheet showing a nosepiece. I have a parts catalogue that shows the nose piece with its own part number. There’s also a picture of the nose piece with the attaching hardware.
If you can scan or photo that, would be excellent.
My car is a Oct 1967 build, so could be it had it. Where on broadcast would it be listed?
I need to lay it on top of my restored grille. If it matches well, then I am leaning to install. If the argents are way off and does not look right, that may break the deal. I dont want to repaint the NOS part.
