Bolt pattern and throttle bores were good on the 4160 I had. Issue is the linkages on the left and right side. The carb I started the fit with also had an electric choke. The choke idle screw hit the intake on the rh side. The LH side throttle linkage that hangs down hit on the left side of the intake.
I suppose I need a spacer to raise that carb up a bit?
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
