anything can be done... maybe custom linkage system and served.
The "bigger" problem could be the cylinder system linkage ? being A and B bodies separated from the handle and E bodies as ( somehow ) part of the assembly without disturb one with the other ?
Maybe using the cylinder link from the E body and the handle link from the A body... both with tweaks on the opposite end.
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
