Did a net search. Found this
http://dave78chieftain.com/Ignition_Syste.html
I checked for 12 volts to the number one pin receptacle. Nothing. Same for number 2 pin, same result. I checked for voltage at the ballast resistor and I’m good there. Looks like it’s the harness. Just for shits and grins I went ahead and ordered one last night just in case.
“So if it’s on the internet it must be true”
Abe Lincoln
