Originally Posted By Satilite73
Has the plenum gasket and timing chain (tensioner) been done yet?
They're stout little trucks. If you can keep the rot away, 10 yrs shouldn't be that difficult.
The plenum is in process.Check this guy out...the Kegger wizard. http://utawesomeperformance.com/index.html Will be doing VRP mod if I can find a cheap '99 up intake. Engine sounds tight and runs perfect so timing chain will wait for when I pull the engine this summer smile
