Originally Posted By Cab_Burge
Some thing to think about on peak flow versus maximum lift, it you buy and use a cam the has .600 lift won't the motor flow more air at .500 twice than only at .500 lift max, if the flow slows down above .500 but it is still flowing more air up until the valve reaches .500 again when it is closing ,right work
More air and fuel equals more power, correct shruggy
You have to remember that on a fast rate of lift cam sometimes the lift has to be higher than the cam designer might want or need. He can't just square off the top of the lobe because the lifter would not be able to follow the profile without floating. He needs the extra lift from the lobe to "slow" the valve down so it can reverse direction and start closing without floating. This allows more dwell time at the maximum flow of your heads and hence more power.
