Originally Posted By RapidusMaximus
It's tight but corroded and as a side note this came from the melted side which is also the ground side. May not mean anything but it shows continuity from end to end.
Continuity at zero current is one thing, the ability to pass current is another. The higher the draw (current wise) the more critical connections and contacts become.Those fuse box connections are TOASTED (No pun intended)
beer
