Originally Posted By Adrielp
Why wouldn't 0.842 keyway lifters work? You would definitely need to have a custom one off valvetrain to accommodate any additional lift. Seems like even the new Jesel and T&D rocker arms are still limited to certain amount of lift. If you could get that figured out, I think that you may be able to make some things happen.
Who makes an .842 Keyway Lifter? The Jesel System that uses the cradle and individual Rockers has ratio options.
