Originally Posted By Mr.Yuck
I would not use caltracs on anything other than a drag car. they make the ride rough and it will be worse around corners.
Dad and I put a set onto his Diplomat coupe last year and I didn't think it was bad at all. Even has the solid aluminum front spring bushing installed. Car is setup for handling with high rate torsion bars, sway bars and stiff shocks.
We did a before and after cruise down the same stretch of road to compare. This is route I was planning to take in the Spring.
1987 Fifth Avenue - 512/518/D60
