here is what i am contemplating :
440 block bore 4.360
rods 6.768 long h beam
crank mains & rod are std. 4.15strk both rods & crank are eagle
pistons ross 12.5:1 comp
mains & head are studs
mylodon single stage hv (have 2 stage set up )
heads mopar stage v 2.250 in. 1.8ex,single stage intake ,no carb,no dist,
no water pump(have used meziere electric,if interested this is option??
roller cam crane 1.5 rockers cam I believe to be comp cam
this, plus a rollerized A&A 727 with RMVB and aluminum drum for around 6500. other parts are available, but i don't know exactly what. my thoughts were to use my MW intake, and install with 2" TTI's in my charger after an inspection and refresh.
thoughts ?
![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
