probably a dr diff question. or andyf.
I don't know b-bodies that well.
I know for c-bodies, which doesn't exactly help, that in 69 the spindles changed.
everything bolts up from 65-73, suspension wise. whole setups will work.
but you can't swap individual parts between them.
Like the rotors don't work between certain years. 68 won't work on a 71 etc..
I imagine part of it is the budd disc system that went away in 68.
The other question would be are you sure it is a factory disc system and not an aftermarket?
The old disc brake system was aftermarket as well.
The diameter on the 65 spindle seems to be a touch larger.
