RWAL is pretty terrible too...
In general, if you have rear drums, you need to swap to some properly sized rear disks, and then you will not have a rear wheel locking problem that can't be easily tuned with an adjustable prop valve
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
