Originally Posted By Neil
I just put a set of the Hella HID conversion lights I bought from Summit in my old Chevy pickup to replace the old oem style sealed beam halogen lights and they are way better. No mods required at all, even the factory stainless GM trim bezels that go around the lights fit.
The high setting is absurdly bright, so much so that I know they would 100% blind people coming the other way.
They look pretty stockish and are DOT approved.
http://www.myhellalights.com/index.php/products/auxiliary-lamps/sealed-beam-conversion-headlamps/
I used them on a 2 headlight car I had years ago,MUCH brighter and high beams were blinding! Also like the way the glass was fluted.You can also put a brighter bulb in!
They are on my bucket list!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
