Originally Posted By 4406bbl
Hemi 4-speeds had them from the factory.
None of them that I used did confused I raced them from pre mid year 1969 model years though shruggy
I worked for the local telephone company back then and I would remove the magnets from the bad ringers, usually the coils would go open, and epoxy them into the drain plugs up
I've seen some of the later aluminum case O.D. 4 speed tranny with a magnet fastened, glued, inside the cases on the bottom also work
OP, if your dealing with a stock cast steel case slide it in near the drain plug and use it that way scope twocents up
