Originally Posted By DAYCLONA
Originally Posted By dart4forte
Need to lube up my window mechanisms. Any grease recommendations?
I usually try and avoid most of the greases, esp white lithium,as they "cake" with age, I use cam moly lube on the rollers/regs, and dry graphite spray on all the slides... after a through cleaning/repair/replacement of all the reciprocating window mechanisms
Yeah, appears that someone used lithium at one time. All caked up.
“So if it’s on the internet it must be true”
Abe Lincoln
