If the van runs you can put an old style voltage regulator on it to control the alt field and have it charge. I have done this before when people did not want to replace the PCM if the charging problem was the only problem with the PCM. But it will most likely set a code in the PCM for the alt field circuit since you have to cut the field control wire to the PCM and wire it up to an ext regulator. Ron
