There was a post a few weeks ago on shocks. Didn't see an answer for a lower HP. My latest build is an A body with about 390 HP. For simplicity, I'm using SS springs. 30 years ago, you just looked for the longest rear shock and that was it. Not a lot of selection now and most shocks, that are available, are only online and there are no length specs. So looking for a shock recommendation using a DOT drag radial, street/strip car. I thought of the Rancho adjustable but couldn't find shock length. Is longest shock length not a good solution for SS springs?
