there is a machined groove at the 0 mark. The timing cover has markings from about 0-20 BTC/ATC.
sucess!. You would want the machined groove on the harmonic dampener to be at the appropriate mark on the timing cover(& check your tune up manual & see where you want it) but 10BTDC would get you fairly close. If you are not pinging at any point in time no damage is being done.
