Build it like a boat motor, they often run like that out on the lake. You might consider an oil cooler but other than that a good high performance build should handle it. Keep the compression reasonable, clearances on the high side and use high quality parts in the valve train.
Exactly. Nothing special. Just understand that it will wear our much faster. That you really cannot change.
